Skyjacker question...
Old Mar 28, 2011 | 08:57 AM
ag_golf2011's Avatar
Default Skyjacker question...
What is the difference between a standard skyjacker 4 in. Lift and the skyjacker economy 4 in. Lift other than the fact the economy lift is cheaper?
Old Mar 28, 2011 | 10:49 AM
nthinuf's Avatar
The components.
One has Fixed Lower control arms to adjust the caster, the other has Cam Bolts.
Open the Drivetrain FAQ's and read "what is caster? how much do I need?" And then do a quick search on Cam Bolts. Your other options for caster correction are Drop Brackets (rancho and aev make them, not sure who else), and Adjustable Control Arms.
Old Mar 28, 2011 | 12:03 PM
Torrin's Avatar
I would say Junk and more Expensive Junk. You will not find a lot of folks here running Skyjacker. Most folks that purchased it, took it off.
Why don't you let us know what you want to accomplish and we can help you out.
Old Mar 28, 2011 | 01:36 PM
jagermeister427's Avatar
Do not by skycrapper... my control arm bushings failed in 2 years... Shocks blew out... I wouldnt recommend them... Go with Currie!!!!
Old Mar 28, 2011 | 02:00 PM
kellyII's Avatar
X2, I purchased my JKU and it has a skycrapper lift on it. Shocks were pure s**t, the lift overall is not what I would have bought at all. Let me get my other goodies bought and this lift will be replaced..... just my .02
Old Mar 28, 2011 | 05:38 PM
Joisey's Avatar
steer clear of sky jacker
you want to look into teraflex, old man emu, or if your on a budget rough county
Old Mar 31, 2011 | 06:21 AM
I'm pretty sure I am going to buy the 3 inch Teraflex standard lift with shocks. Will I have driveshaft problems with this lift? Or any other problems?
Old Mar 31, 2011 | 06:31 AM
Torrin's Avatar
You might, 3" is right on the edge.
Old Mar 31, 2011 | 06:36 AM
Norm's Avatar
As stated above. Stay away from Skyjacker. I am slowly replacing all my components with TeraFlex. Every time I look under my Jeep, another part is bad. So far I have replaced the springs and swaybar links. Just noticed the bushings on the control arms are bad.... it just keeps going....
Old Mar 31, 2011 | 09:45 AM
nthinuf's Avatar
Expect 4" of actual lift. With an auto, plan on having issues with the front shaft. With a 4door, the rear shaft should be ok.
