Sline count
Old Feb 13, 2011 | 01:50 PM
ssgthooligan's Avatar
Default Sline count
I am getting ready to by a set of gears and a locker for my JK Sport. Going to buy an Auburn Ected locker for rear/ 4:88 gears for front and rear. Which ones do I select? spline count?
Ooops Spline count
Old Feb 13, 2011 | 02:04 PM
nthinuf's Avatar
Non-rubi
D30 front - 27 spline inner, 32 spline outer
D44 rear - 30 spline
Rubi
D44 front - 30 spline inner, 32 spline outer
D44 rear - 32 spline
Old Feb 13, 2011 | 02:07 PM
wayoflife's Avatar
JK-Forum Founder
Originally Posted by nthinuf
Non-rubi
Rubi
what he said. of course, since you are installing new lockers, you may or may not want to consider installing a beefier set of axles - say, 35 spline
Old Feb 13, 2011 | 03:05 PM
Default Spline count
I want to beef up the front axle to handle the 35's. So I figured do the C gusset up grade with the tubes and 4:88 's for gearing.
For rear add 4:88 and an Auburn Etec locker.
Old Feb 13, 2011 | 09:15 PM
nthinuf's Avatar
Not sure how much research you have done, but thought this may interest you
Originally Posted by Dynatrac
The Auburn Ected looks great on paper but the actual function is poor when compared to the others. This unit is based on a clutch driven limited slip design and doesn't truly 'lock'. When 'locked', extra pressure is given to the clutches and it will act locked unless there is enough engine torque and traction to overcome the clutch pressure. Additionally, over time, the clutches will wear and lock up will be even less effective. If that wasn't bad enough, the internal side gear design has very little axle spline engagement in the LSD mode and axle shafts have been getting the splines stripped. Auburn is working on a new Ected model that is said to address these issues.
And the full thread, if you decide to do a little more 'looking'...
https://www.jk-forum.com/forums/show...ighlight=ected
And one more
The Ected is not really a 'locker'. It locks through the clutches can be overcome by too much torque. We've seen these slip when someone is trying to climba ledge. If the clutches wear (which make it slip easier) it can't be rebuilt, only replaced. Auburn has a 4 year warranty where you pay a fee for replacement but after 4 years you're on your own. Do you want to buy a new unit when your clutches wear? Clutch driven LSDs are a bad idea on an off road rig as any free spin of a tire accelerates clutch wear.
Another issue is their side gear design. In the unlocked mode (now LSD) only one side gear is using the full spline engagement. The other side has a 2 piece side gear that, unlocked, only uses about 9/16" of axle spline engagement. They have been having issues with stripping splines off of the axle.
Old Feb 14, 2011 | 06:34 AM
Dynatrac's Avatar
Sponsoring Manufacturer
Another question you'll have to answer is gear ratios for the carriers. Despite your 4.88 rear gears, you'll need a 3.73 down rear carrier, NOT a 3.92 up. The front will be a standard 3.73 up 27 spline Dana 30 carrier.
As for the Ected..
Old Feb 15, 2011 | 01:38 PM
Default spline count
Whats wrong with a ected?
As for the Ected..
Old Feb 15, 2011 | 01:42 PM
nthinuf's Avatar
You didn't read the quotes or follow the links in post 5, did you. They are both by Dyna, so a simple frownie emoticon was all that was really needed when they posted.
Old Feb 19, 2011 | 07:49 AM
Ok, read the posts. Airlocker it is. Glad I didn't order!
Old Mar 28, 2011 | 07:32 AM
Mr_wiki's Avatar
Non-rubi
Rubi
Didn't really get in to diffs yet. Im thinking about a locker for front Dana 30. But my question to you is what do you mean by "27 spline inner, 32 spline outer"? And any suggestions on a locker?
