Slow build what you recommend?
Well its starting......
I have just ordered Old Man Emu LT shocks(thanks Northridge4x4.ca). Going to be ordering stuff over the winter piece by piece so it doesnt hurt the bank to much. This is the list I have and the order I plan on ordering stuff. Let me know if I am needing anything else.
OME LT shocks (ordered)
OME HD Colis
Spring Retainers
Extended Bumpstops
Brake line extensions
front and rear adj TB's
front lower control arms
16x9 ATX Artillery's 315/75/16 Toyo M/T's (Deal in the works with fellow JKer)
Thanks for any input looking for what brands you guys are using and recommend for TB's and control arms. cheers Steve
OME HD Colis
Spring Retainers
Extended Bumpstops
did you get standard length shocks or extended? if you got extended, you'll want the new coils to match as you will bottom out the shocks. bumpstop extensions (front and rear) are cheap and you should get them at the same time as your coils. extended brake lines are nice to have but not necessary up front for the amount of lift you will have. rear extension brackets are all that you really need.
