Is this small crack a problem?
Old Apr 27, 2013 | 09:50 AM
web architect's Avatar
Default Is this small crack a problem?
I've been fighting the GASCAP and 0456 codes forever. Sometimes the larger leak code, and once a blockage code. Already did a new Mopar has cap. All lines look good.
Found this crack in the evap can today.
It looks innocent enough to me, but what do you think?
Old Apr 27, 2013 | 11:31 AM
dcharge74's Avatar
Throw some RTV on the crack and see if the codes go away. I would guess that crack is the culprit. You could just get a new EVAP can too. They're only $50-60 at the dealer.
Old Apr 27, 2013 | 03:26 PM
toolow262's Avatar
Veteran: Coast Guard
x2 ^^^^ If you have some laying around or JB Weld. This is a good temp fix to see if the codes go away, new ones are cheap but 50 bucks is 50 bucks so don't waste it if its not the issue.
Old Apr 27, 2013 | 06:50 PM
Rocky Clymer's Avatar
Be a bit careful. The evap can has a lot of powdered carbon in it and if it is leaking bad (it runs under a vacuum most of the time) it can suck the carbon back up into the system...this happened on my Subaru and I am sure all systems run pretty much the same. You may still get a code if this has happened.
Old Apr 28, 2013 | 06:00 AM
So, Rocky, are you suggesting that sealing it up is a bad idea? What do I need to be careful of?
Thanks!
Old Apr 28, 2013 | 06:07 AM
Mark73's Avatar
If its broken inside it will still throw codes blockage code I'd guess
Old Apr 28, 2013 | 08:18 PM
That makes sense. Have the new can standing by, just waiting to see if the dash lights up first (post tape job).
Old Apr 29, 2013 | 12:26 PM
D_engel's Avatar
My jeep just threw this code two days ago. I gotta crawl under and find the crack. I hope a little RTV will be the solution because I really dont want to replace it if its barely cracked.
Old Apr 29, 2013 | 05:07 PM
jk bobby's Avatar
Crack kills! Get that fixed before more codes pop up and leads to more problems.
Old Apr 29, 2013 | 05:18 PM
mpkelley20's Avatar
Just a little suggestion....that code you are getting is usually just a bad seal on the gas cap. The "gascap" code and small and large evap leak are 99% of the time due to a gas cap that is leaking vapor/not sealing well. It's a very common issue.
I had the same issue and swapped out to a new cap from autozone for $15 and no more codes.
I'd try a new cap, clear the code if you have a tuner and see if it comes back. While I understand you have that crack on you canister, I'd bet its not the problem.
