smallest rim size on jk?
Old Oct 27, 2008 | 05:24 PM
1AK-JK's Avatar
Default smallest rim size on jk?
what is the smallest rim i could put on my jk? i was thinking on putting 15' does anyone know if 15 would fit?
Old Oct 27, 2008 | 05:27 PM
mikeyfl's Avatar
from the modified faq:
Q: Will 15" Wheels Fit on my JK?
A: Most steel ones will fit without any problems and depending on the thickness of the wheel most aluminum ones will as well. The only thing you really need to make sure is that the wheel clears the brake calipers.
https://www.jk-forum.com/forums/modified-jk-tech-2/15-x8-rims-17449/
i have 15s and they work fine.
Old Oct 27, 2008 | 06:30 PM
N2MWL's Avatar
I have 15's on mine as well, others have not had such good luck with 15's.......It seems some brands fit and some do not..
All my info is in my sig if your interested.......
Old Oct 27, 2008 | 06:43 PM
TxCop07's Avatar
Vet Army
some people get lucky with the 15" and some don't, i would go to a tire shop and let them test fit them first.
Old Oct 27, 2008 | 07:43 PM
Superman1023's Avatar
yes 15s. 8179 pro comp for sure!! they clear brake by about an inch or less close but perfect fit.!
Old Oct 27, 2008 | 08:36 PM
LemonTwist's Avatar
15's definitely fit. Have heard rumors of some needing a slight grinding of the calipers, but mine fit fine.
Old Oct 27, 2008 | 09:39 PM
Choppus's Avatar
Wow, they actually look like they ^^^ are smaller than 15's. LOL
Man those things look tiny compared to the rest of the Jeep.
Old Oct 27, 2008 | 09:41 PM
cyberbrain's Avatar
15 is the smallest you can go. anything else wont even clear the rotor or caliper. i had to use wheel spacers to get my cragar soft 8's to fit. Keep in mind that just because they fit one JK, they dont fit the next.
With steel wheels, no 2 rims are the same. it all depends on the manufacterur's QC and what not.
Old Oct 27, 2008 | 10:43 PM
gt4660's Avatar
Backspacing is the key, plus rim design. have one test fitted to ensure. Also do the search on here. This has been discussed, but noone has made a list of all that will work.
Old Oct 28, 2008 | 03:24 AM
ledcubbie's Avatar
15s with 4 to 4.5" backspacing should work well for you
