Snow Issue
Old Jan 5, 2012 | 12:49 PM
  #31
JKCloak's Avatar
Originally Posted by Audiodogg
In 4HI does the TC stay off completely? That's the problem, her's keeps kicking in. 2wd is fine it'll turn off and in 4LO it automatically disengages it.
Nate
The TC will turn off in 4hi if you press the button!
Old Jan 5, 2012 | 01:01 PM
  #32
WhosUrBuddiee's Avatar
I think you just had too little snow.
Old Jan 5, 2012 | 01:05 PM
  #33
Maybe you just need to upgrade your tires to these.
Old Jan 5, 2012 | 01:07 PM
  #34
gtrman33's Avatar
Doesn't matter what you are driving, often times there is that slick layer of black ice under the dusting that will make you slide around out of control. I would give it a few more runs in deeper snow before dumping money unless you have it and then go all out!
Old Jan 5, 2012 | 02:02 PM
  #35
BIGTom's Avatar
The small amount of snow we had and the fact that it has been below the freezing point for two days leaving the ground very cold allowed the snow to compact down into ice after the first vehicle went over it. It just looked innocent but everyone had trouble on the stuff this morning. I have the rubicon tires on my Jeep and slid to a stop when going under 20mph and felt the tail end slipping around at that speed also. I suspect it will be the same when the snow is packed hard two days after a significant storm if one ever gets here.
That's not stopping me from wanting a foot or so to play in this winter.
Old Jan 5, 2012 | 06:14 PM
  #36
JKCloak's Avatar
lol that's a given typically. It wasn't turning off on her Jeep in 4HI hence why I asked I'll have to check it out again then and make sure there's no problems cause it was disengaging in 2wd and 4lo just not 4hi.
Thanks,
Nate
Haha sorry man, that's wierd though
Old Jan 5, 2012 | 06:48 PM
  #37
03fatboy's Avatar
Those look grippy!!!
Old Jan 5, 2012 | 07:01 PM
  #38
Branden08JK's Avatar
Originally Posted by SolarJKStar
Transfer case is engaged.
I'm running KM2's currently which have about 25k on them.
I could not believe how much I was sliding around...heck my old 2 door YJ on 36in swampers didn't have this much trouble.
I'm running brand new 35 in KM2s , great in mud dirt and deep snow , but get them on hard packed snow and it's pretty bad I aired down a bit and it helped , might sipt the center treads on the km2s , I think someone on here did it and had great results .
Old Jan 5, 2012 | 07:48 PM
  #39
WYO-JK's Avatar
Same thing happened to me with my km2s...I bought some Cooper discoverer at3 s for winter and the difference was night and day
Old Jan 5, 2012 | 08:29 PM
  #40
hagausaf's Avatar
35" KM2's here and got no issues at all driving in snow and ice. Mine arent siped either, i just downshift when I need to slow down and use the brakes only when i have to. We had some crazy ice on the roads here in Colorado last week and I didnt slide around at all. I'm also aired down to about 25psi which helps
