Soft top rear window
So...when it comes to everyday tasks, the soft top rear window is a pain. The 10 inch opening that you get when you open the gate its enough to slide the gym bag through but putting groceries in sucks. Anyone have a mod the open the window easier or is there a product out there that makes opening the rear window an easier task?
The way I do it is zip both sides up to the top then undo the two small retainer strips then flip the tailgate price and the window all in one on the roof of the soft top. Easy enough for me and only takes a few seconds. Definitely not as easy as the hard top though.
I also had them try to handle an instruction sheet for the soft top, which I promptly told them they could keep for the next customer as this wasn't my first rodeo.
I have an old top that I didn't mind getting stained. I used PB Blaster dry lube. It sprays on wet and is dry when it, well, dries. I applied it in the spring and it is still working smoothly. The high pressure made it splatter on my black top, but now you can't tell. I would strongly advise trying to avoid the splatter if you care about the appearance of your top.
