Solenoid mounting??
Old May 8, 2007 | 06:32 PM
oskee6's Avatar
Question Solenoid mounting??
So for the solenoid on the Warn 9500 - does the bracket mount on the allen screws on the drum? Also, does the motor ground screw into the that allen screw on the motor? The instructions were less than clear to put it mildly.
Thanks!
Old May 8, 2007 | 07:19 PM
POTO's Avatar
The solenoid mount for mine used the allens that hold the chrome guide bars. And the ground wire should go to something metal (frame, winch mount plate, bumper), something other then the winch. You might have to drill and tap a hole. HTH
Old Jun 26, 2007 | 07:35 PM
pulman01's Avatar
Any pics of yours mounted? I put mine on several different times in different locations, finally pulled it off and decided to do it tomorrow after a little frustration. Seemed like the best position was on the front left guide bar, but after wiring it up, I just didn't like it. I might have to leave it there, but wanted to try and research what other people are doing.
