Solid Axle Hub conversion at sema- Pictures added
Old Oct 18, 2007 | 01:39 PM
Piginajeep's Avatar
Default Solid Axle Hub conversion at sema- Pictures added
I heard a rumor that Solid Axle Industries will be displaying the SpynTec hub conversion at Sema and it'll be release sometime in january.
Old Oct 18, 2007 | 02:00 PM
wayoflife's Avatar
JK-Forum Founder
LOL!! You just talk to Matt today too?
This is something that I'm definitely gonna want
Old Oct 18, 2007 | 02:01 PM
Piginajeep's Avatar
I need to get a front 44. then it will be a must have!
Old Oct 18, 2007 | 02:03 PM
wayoflife's Avatar
JK-Forum Founder
Ummm, I'm pretty sure that 4WD.com has some for a reasonable price
Old Oct 18, 2007 | 02:08 PM
Piginajeep's Avatar
Its on the list! along with flat fenders and a long arm kit..
the damn money tree isnt growing...
Old Oct 20, 2007 | 04:05 PM
Blue's Avatar
I believe there may be as many as 3 companies working on this and Warn isn't one of them for some reason.
Old Oct 22, 2007 | 12:08 PM
Bluewaterrider's Avatar
Question JK Manual hub conversion
Just my thoughts on this.
I suppose the benefits of this are:
1. A lot less wear and tear on the front diff, front drive shaft and front output shaft bearings on the X case............... But why should most of us care with a LIFETIME warranty on all these parts??????
2. Better gas mileage. . ....BUT I will almost guarantee that if you do this conversion and a U-joint, outer axle shaft bearing or carrier bearing goes bad that Chrysler will not cover it under the lifetime warranty because of the conversionwith non Mopar parts.
3. If you bust a front end U-joint you can go back to TRUE 2wd and limp home.
I would really like to do this conversion once it is available BUT I am not gonna do jack S#!t to my JK that is gonna void the LIFETIME warranty.
Old Oct 22, 2007 | 12:15 PM
Piginajeep's Avatar
If your built up enough, you wont have a warranty left anyhow..
Hell they wont even cover parts on the 3year 36,000 mile. with what mild modifications I've done to mine.
I'm going to look into this as well. I still have slight driveline vibs from the front shaft at highway speeds, this would solve my problems..
Old Oct 22, 2007 | 12:32 PM
SabrToothSqrl's Avatar
Default word
just more parts to break.
Jeep abandoned unlocking hubs after the YJ...
Old Oct 23, 2007 | 12:00 PM
Blue's Avatar
That's is not a valid argument. Just because Crappler does something doens't make it a good idea or reason.
