Something don't seem right
Old Mar 11, 2011 | 01:35 PM
Lyman21's Avatar
Default Something don't seem right
Try to make this as quick as i can. I got bfg km2 305/70r 16 tires just put on. I also used the procal to tell the computer the new tire size. 32.5 is what i inputted. (used a tape measure from ground up to measure)
Today was the first time i did a highway run on the new tires.
At first it seemed right, i was getting 19 to 19.9 and no higher and this is from almost 22 mpg w/ the stockers
Riding along at around 65, i turned off the heat completley and the mpg shot up to 21.5
I didn't expect to be getting that much w/ the bigger tires. Does this seem right to any of you?
anyone experience the same thing at all?
Old Mar 11, 2011 | 01:38 PM
sringer's Avatar
stock jk tires are 32"...so i dont see why that wouldnt be right. and ive always been told airconditioning and heat makes you get worse gas mileage
Old Mar 11, 2011 | 01:40 PM
Hellbound13's Avatar
Consider yourself lucky. I am getting 15 with the stock tires!
Old Mar 11, 2011 | 01:42 PM
sringer's Avatar
ya...i was getting 11 with stock tires and a 2.5 bb now i dont even wanna know what i get with 35's....
Old Mar 11, 2011 | 01:43 PM
JK.nick's Avatar
Im getting 12 with my 35s. But I haven't re-calibrated the computer yet, so it may be different.
Old Mar 11, 2011 | 01:46 PM
sringer's Avatar
i went to my dealership to get my speedo/computer recalculated...they could only select up to a size 32 tire...and im running 35's...my speedo will always be 9% off
Old Mar 11, 2011 | 02:36 PM
Feasterdef's Avatar
What gears u have? I have a 2 door soft top manual with 35s and get 19-20 on highway running at 65 with 3.73 gears. My speedo hasn't been calibrated but I know my speed from my gps. So technically I am getting a little better on the CPU. When I do the mileage divided by gallons filled up on I am getting 18-20 highway.
Old Mar 11, 2011 | 02:59 PM
sringer's Avatar
i havent changed my gears...i have stock 07 2dr x gears. i dont have the computer thingy in my jeep...i divide miles by gallon and got 11 before my tires
Old Mar 11, 2011 | 03:08 PM
renpia's Avatar
11 mpg stock??? I was getting 19-20 mpg on my stock X tires & 3.73 gears before lifting and going to 35's (doing the math & GPS, not speedo). And with lift and 35's I was getting about 15 mpg. I just recently put on 37's and will calculate the mpg. I'm going to guess it will be in the 12's.
Old Mar 11, 2011 | 03:11 PM
renpia's Avatar
Did you check via GPS that your speedo is accurate? I have to play with my tire size settings with the Superchip and adjust the size until my speedo matches the speed in my GPS.
