Something Loose in the Front End
Old Mar 26, 2009 | 07:32 AM
derekjm14's Avatar
Default Something Loose in the Front End
I just installed a 2.5" Rough Country Coil lift and a 1" PA body lift over the weekend. I also mounted a set of 35x12.5x17 mud terrains on a set of cragar soft 8's. I have driven it all week with no problems, but today it started making some a noise. It sounds like something is loose. When I have the wheel turned and I hit a bump something bangs around in the front end. I am thinking one of the shocks must have worked itself loose and I am going to go through and double check all the bolts to make sure everything is tight. Does anyone have any other suggestions?
Old Mar 26, 2009 | 07:40 AM
mkjeep's Avatar
Do you feel it in the steering wheel? Could be a loose shock, check those top mounts. I got more of a pronounced clunk in my steering after my bodylift. It was the splines in the intermiate shaft. It sounded like a loose shock when turning.
Old Mar 26, 2009 | 07:42 AM
wayoflife's Avatar
JK-Forum Founder
check the bushings on your shocks. i have seen a few RC shocks have issues with them splitting. also, check your sway bar links as they might have come loose at the sway bar itself.
Old Mar 26, 2009 | 07:52 AM
derekjm14's Avatar
Thanks for the suggestions! I will definately take a look at the sway bar. I honestly can't remember if I could feel anything through the steering wheel or not. I'll pay attention on the drive home and see if I notice anything. If it is the steering is there anything I can do to correct it? Hopefully the bushings on the shocks didn't split, they were a huge pain in the ass to get in there in the first place.
Old Mar 26, 2009 | 08:10 AM
mkjeep's Avatar
If it is the intermidiate shaft, some people have had luck with greasing the splines, I ended up putting in a new shaft, grease didn't work too long. Check the stuff WOL said first and then it's the process of elimination.
Old Mar 26, 2009 | 09:47 AM
09rubicon's Avatar
I would also check the trackbar bolts, my lower (axle side) bolt worked loose on me twice, a little blue locktite and no more issues.
Old Mar 26, 2009 | 10:31 AM
derekjm14's Avatar
Well, i was playing around with it on my lunch and I think i found it. The front drivers side body mount bolt had worked itself loose. I'll use some more thread locker and tighten it down when I get home tonight. Hopefully that take care of it. Thanks for the suggestions!! I'll probably go around and double check everything anyway. Better safe than sorry.
Old Mar 26, 2009 | 10:32 AM
wayoflife's Avatar
JK-Forum Founder
cool. glad to hear you found your problem and that it was nothing serious
Old Mar 26, 2009 | 11:08 AM
derekjm14's Avatar
Yeah, no kidding. I have a really bad habit of assuming the worst. I kept thinking I was going to get halfway home and have a shock fall off or something will brake and then have a bigger problem to fix.
