Which Spacer?
Old Oct 11, 2011 | 01:51 PM
w squared's Avatar
Good quality hub centric spacers will last a long time and are perfectly safe when installed correctly and maintained.
If you choose not to buy the good ones...your results may vary. EBay is not somewhere that I would consider purchasing wheel spacers from.
Old Oct 11, 2011 | 07:50 PM
derby911's Avatar
I would go with the spidertrax. Another member had a set test along with a differant brand. The spidertrax tested better than t6061 aluminum and grade 8 wheel studs. the other did not and the wheel studs didn't even test to grade 5 even though they were marked as grade 8 . your safety has to be worth an extra $40
Old Oct 11, 2011 | 11:31 PM
Rub61's Avatar
I would like to hear from the people that have had failures with the cheaper spacers. That way we can really bad mouth them.
