spacers??
Old Oct 23, 2013 | 06:42 PM
jlfuksa's Avatar
Default spacers??
Getting 35x12.50x17 mud grapplers for JKU with 3" lift, be mounted on stock wheels, will I need spacers??
Old Oct 23, 2013 | 06:44 PM
jlfuksa's Avatar
My AT's on right now are 315 70's and no rubbing issues just curious about the 35's being wider would need spaced
Old Oct 23, 2013 | 07:06 PM
myrojk's Avatar
Yes you'll rub the front tires
Old Oct 23, 2013 | 07:08 PM
myrojk's Avatar
I run same size with a 1.25 bolt on spacer (don't go cheap on your spacer don't want a wheel rolling down the highway on ya)
jlfuksa's Avatar
Ok thanks, 1.5 do the trick??
Old Oct 23, 2013 | 07:12 PM
kh202's Avatar
. Yup that's the most common I'd say. 1.5" Spidertrax
Old Oct 23, 2013 | 07:14 PM
nthinuf's Avatar
Getting 35x12.50x17
Doesn't a 315/70/17 = a 35x12.50x17?
Old Oct 23, 2013 | 07:46 PM
karls's Avatar
They're close, but everyone measures a little differently. According to the math though- those tires should be split wide open on the inner sidewall in the rear.
Sent from my DROID4 using Tapatalk
Old Oct 24, 2013 | 06:14 AM
Matthewd5's Avatar
Yes, I'd be surprised if you could run those without spacers...
Matthew
Sent from my iPad using JK-Forum
Old Oct 24, 2013 | 06:17 AM
Ryan0260's Avatar
Yes, you will need them. Stick with a reputable brand and follow the manufacturers directions when installing them. Also, do a chalk test to make sure the tire has a flat contact patch with the road. This is important when running them on the narrower wheels.
