Which spacers to get
Ok, these are the 2 I am looking at.
DO these look right?
http://www.quadratec.com/products/16190_0009_07.htm
http://www.roughcountry.com/jeep_jk.html
http://northridge4x4.com/proddetail.php?prod=TF-1155200 this is the same kit u selected, but cheaper and free shipping!!
I am leaning towards the TF one, due to the fact it has sway bar links provided
I now have the JKS links, which are adjusted to be longer than stock, to keep this from happening again. I do not know if the TF links are compatible with the Rubi or not.
Anthony
I would say: Get a spacer kit, shock extensions or new longer shocks, and longer / adjustable sway bar links, and you will be good to go. If you can find a kit that has those three things together, and is in your price range, than so much better!
Like I said, I am running the RC kit with shock extensions, ran the stock sway bar links for a while (knew that they could be damaged, but ran them until I bent one
), then I upgraded to adjustable links. No problems now.Anthony
