Spare on tailgate - lets settle this once and for all
Old Jul 17, 2008 | 03:48 PM
lv jk's Avatar
***erator
I have 35x12.50 baja claws here is a pic of the fit. Close to the bumper.
No problems in 1500 miles. Mixed on and off road.
Old Jul 17, 2008 | 03:55 PM
69thunderbird's Avatar
Default no problems Mickey MTZ 315/34.6" (aka 35") tires
1. What parts/products they used to make room for the bigger tires and accomodate a 3rd brake light,
> None
2. How long they ran with this setup (time or miles)
> 3 weeks 2000 miles
3. What kind of abuse has it been getting over this time (highway, off-road)
> rolled the jeep, been off road 4 separate occasions
4. Any side effects to date? Deformation of tailgate, bends, dents, etc.
> none
Old Jul 17, 2008 | 05:25 PM
mikeyfl's Avatar
  • cragar 15x8 with 3.75bs... toyo op co 35x13.50. stock carrier.
  • 6k miles.
  • mild off roading.
  • none issues to date.
Old Jul 17, 2008 | 06:49 PM
chumpmann's Avatar
35x12.5 mounted on 15x8 mojave teflon with 3.75 backspacing.
None, the backspacing of the rim helped.
Actually only about a month
Done some moderate offroading, and it is my Daily driver.
None.....
Old Jul 17, 2008 | 07:33 PM
FunWagon's Avatar
Thanks all. To summarize so far it sounds like 35s may fit with no modifications depending on the wheel backspacing and width and tire width. If anything a spacer is sufficient to move tire out to clear bumper, but brake light always clears. Some have experienced some body side effects issues. May be a good temporary solution.
No information yet on 37s on stock tire carrier with any brackets, but people have a bad feeling about it. One person has 37s on the Bestop tire carrier for a short period of time and is happy with it. No bad reports of 37s on the Bestop carrier.
Old Jul 17, 2008 | 07:43 PM
LSU-JK's Avatar
Default only a few hundred but goog so far
I had a rough country and took it off. it looked bad way too far out from the tailgate. 3rd light is visible with a 35/12.5 and it looks nice. I will get a bumper tire carrier, but i dont think its an urgent matter. Im not sure how uch heavier the larger tire is. If i keep it on for a while i plan on spacing out the "bumpstops" between the tailgate and tire, the aftermarket wheel has the rubber farther away from the gate by a couple of inches. In my situation the spacer put the tailgate in a far worse shape because the farther out from the tailgate with no support from the tailgate via bumpstop(not sure of the proper term) the more leverage pulling down. Just my thoughts, I think this is probably a case by case situation.. Thanks
Old Jul 17, 2008 | 07:49 PM
JulietKilo's Avatar
I just weighed my 35 inch tire and aluminum 17x8.5 inch rim.
97lbs
Stock Rubi tire and rim I think was 72lbs?
Old Jul 17, 2008 | 08:07 PM
Rustler's Avatar
I have a LOD standard rear bumper for the JK and I made my own bracket, for the brake light.
Old Jul 17, 2008 | 08:31 PM
x No Compromise Offroad x's Avatar
I just had my 33" tire mounted to the stock set up and waffled my tailgate (that's red neck for F**Ked up ) wheeling a little hard...I took a steep incline a lil too fast and hit the spare on the ground right before the hill
Old Jul 18, 2008 | 02:25 AM
snippy's Avatar
But that has nothing to do with mounting a non-stock tire on the stock tailgate right? I mean, even if you have your stock 32" on there, and you wheel it into the ground, chances are there will be damage.
