Speedometer
How much difference depends on what you had.
I would get a ProCal to input the correct size.
An easy and accurate way to measure tire diameter is stick a little piece of chalk in the tread, roll over it twice, measure the distance between chalk marks, and divide by 3.1416.
You can check the difference at Tire size calculator so you'd be off by 5.4%. Hypertech and Daiblo make programmers that enable you to adjust for tire size changes.
