Speedometer
Old Jul 19, 2012 | 11:42 AM
BlackdogJK's Avatar
Default Speedometer
Just upgraded to 33s. How much is this throwing my speedometer off? In which direction? Programming suggestions?
Old Jul 19, 2012 | 11:48 AM
ronjenx's Avatar
How much difference depends on what you had.
I would get a ProCal to input the correct size.
An easy and accurate way to measure tire diameter is stick a little piece of chalk in the tread, roll over it twice, measure the distance between chalk marks, and divide by 3.1416.
Old Jul 19, 2012 | 12:24 PM
BlackdogJK's Avatar
Went from 255 to 285
Old Jul 19, 2012 | 12:28 PM
EzK's Avatar
EzK
Those numbers don't tell us the height.
But your speedo will read slow now by a few %, not much so I wouldn't worry with a programmer unless you have the spare cash.
Old Jul 25, 2012 | 11:26 AM
Attono's Avatar
You can check the difference at Tire size calculator so you'd be off by 5.4%. Hypertech and Daiblo make programmers that enable you to adjust for tire size changes.
