Spun pinion bearing race
Old 03-19-2019, 01:51 PM
rock7174's Avatar
Default Spun pinion bearing race
Spun the outer pinion race (the smaller one) in my d30. I got it out and it had a little scoring in the bore, but not much. The bearing was burned up pretty bad. I had the original race and bearing from before re-gearing laying around. So I took the original race in good shape and installed to see how much play I had. It actually pounded in like a normal race. My question is, can I just use the green bearing loctite and a new race/bearing? I've read that some people have knurled the inside of the housing, but since the fit is tight, I figured I didn't need to do this. I just don't want to shell out $1,000 plus for a new housing (I'm in Iowa and they aren't laying around cheap). I also do zero off roading with my rig. Daily driver. The only time it sees 4wd is in the winter during snow/ice. Thanks in advance!
Old 03-19-2019, 02:45 PM
Tech Tim's Avatar
Yes, clean it up real good and use the green Loctite.
If you're worried about it, take a punch and dimple a few divots in around the bore before pushing the race in.
Old 03-19-2019, 06:50 PM
Deathtrap's Avatar
There are a few different bearing retaining compounds from loctite, they have the green stuff for different thicknesses/gap ratings, each one has a different PSI rating for strength, their website is pretty good for info.
Old 03-25-2019, 02:16 PM
rock7174's Avatar
So I'm in the process of getting my rig back together. Just used the green loctite and waiting for it to set up. I didn't install these gears and got to thinking what does the rear look like? So I popped the cover and checked the pattern. Backlash was .008. This is the pattern. Would you guys run this? I've set up a few over the years and always try to get coast/drive as centered as possible. I've looked at some pattern charts that say this is ok, but would rather hear it from you guys. Thanks.
Old 03-26-2019, 02:36 PM
rock7174's Avatar
Anyone out there? Would you run this pattern? Don’t really want to tear it down and re-shim it. I don’t have any shins since I didn’t regear it in the first place. Appreciate the help!!!
Old 04-01-2019, 02:16 PM
Tech Tim's Avatar
It doesn't look terrible from that pic, but really it's not a great pic of the pattern to make a call. I would want to see both the drive and coast side clearly.
Old 04-01-2019, 07:46 PM
Mr.T's Avatar
I'd do the entire ring gear and see how the pattern is all the way around.
Old 04-02-2019, 10:03 AM
rock7174's Avatar
I ended up having a mechanic buddy of mine come look at it that does a lot of gear installs. He checked out the entire wear pattern on the ring. Said he’d run it. Also showed him the pic I posted and he laughed at me! Anyways, got about 500 miles in and still going. I posted on the wrangler forum and got beat up pretty bad about how it was going to fail. They were all over me about it. Thanks again!
Old 04-02-2019, 11:52 AM
Mr.T's Avatar
Lightbulb
Great, you're welcome .
Quick Reply: Spun pinion bearing race
