Squeaking in the rear after new gears
Old Jan 23, 2010 | 06:27 PM
phljeeper's Avatar
Default Squeaking in the rear after new gears
I am taking it back to the shop to take a look, but anyone have squeaking in the rear end after a regear? I went from 3.21s to 4.88s about a week ago and after 3 days a squeaking started. It sounds like it is either coming from a wheel or the diff. Any thoughts?
Old Jan 23, 2010 | 06:31 PM
BLK-JK23's Avatar
hmm squeaking?
bad bearing?
Old Jan 23, 2010 | 06:32 PM
phljeeper's Avatar
Originally Posted by BLK-JK23
hmm squeaking?
bad bearing?
I was thinking that too, but they used a full install kit that included new bearings. Maybe I got a bad bearing? The Jeep only has 6k miles on it.
Old Jan 23, 2010 | 06:38 PM
Zylfrax791's Avatar
Maybe they forgot oil... Perhaps the gears aren't set-up properly...
Old Jan 23, 2010 | 06:44 PM
whtIwrk4's Avatar
Could maybe just be a backing plate touching the rotor. It's probably nothing major. If you said growling or whining that would be different.
Old Jan 23, 2010 | 07:08 PM
phljeeper's Avatar
No growling or whining which I would assume would be indicative of a gear issue. The sound is not a constant squeak, sounds like something warped where it squeaks faster as I drive faster. The sound continues in gear or in neutral as well, makes noise any time Jeep is in motion.
Old Jan 23, 2010 | 07:54 PM
mkjeep's Avatar
Check your brake pads and rotors.
Old Jan 23, 2010 | 08:44 PM
nangulator's Avatar
X2, maybe a bent backing plate
Old Jan 23, 2010 | 10:02 PM
BlackNorthernJK's Avatar
I third this....
Old Jan 25, 2010 | 05:18 PM
phljeeper's Avatar
After a full day of troubleshooting it appears that the issue has been identified. The outer seal on the rear drivers side axle shaft was not holding causing a small fluid leak. It seems that the seal issue was caused by a slightly bent axle shaft. I have no idea how I bent an axle shaft on my D44, but it appears to be bent.
I guess I get to join the "I broke my D44 club". What's amazing is that I have a 30 in the front and it has 0 issues.
