Squeaks
Old Apr 17, 2013 | 02:26 PM
jlfuksa's Avatar
Default Squeaks
Noticed I little squeaking while cruising, have a 3" lift, squeak goes away with brakes applied. Not a big loud sound or any grinding just wondering what is? Checked everything under there and seems fine
Old Apr 17, 2013 | 03:47 PM
Gman*2007's Avatar
What type of 3" lift? If you have the spacers on top of the springs, the bolt running thru the middle of the spacer may be bottoming out on the chassis.
Old Apr 17, 2013 | 04:03 PM
jlfuksa's Avatar
It's skyjacker, ok I will check that out! Just greased everything but still squeaky
Old Apr 17, 2013 | 05:42 PM
Staytru06's Avatar
Idk if you have larger tires on your jeep but I'm assuming you do since you said you have a 3" lift. If you have your spare tire in the stock tire carrier that will deff cause squeaking do to the added weight.
