squeaky shocks
About a 3 weeks ago i installed the shocks that came with my rusty's 2" BB. Now the rear shocks are squeaking when i am on a rough road or basically with any movement. i torqued down the bolts and....no improvement. the squeaking is at the bottom end of the shock. how can i make it stop? wd40?
and now i remember why people told me not to go with Rusty's.....because customer service sucks! hillbilly on the phone told me "our shocks don't squeak. must be the way you installed it. torque down harder on the bolts"
is it safe to assume you got the basic old school hydro shocks with your lift? if so, is it safe to assume they came with polyurethane bushings? if so, it's not uncommon for them to get squeaky. really cranking down on the bolts can help... for a while anyway. as mentioned, DO NOT use wd-40 on them. if anything, something like a white lithium grease would be the better way to go.
Daystar, etc, makes a lube specially for the poly bushings.
Sometimes, they squeak because they are TOO tight btw (Or never lubed...)...if you over crank a bushing, it can bind, leading to squeaks...and a crushed bushing...
...which is why, once its crushed, cranking it MORE sometimes takes up the extra gap, and, sometimes, doesn't...depending upon how crushed the bushings were to start with.
all true. i didn't use wd-40. I ended up cranking them to about 75lbs squeak went away....well at least its not noticeable unless you are trying to hear it. If it continues i will try some white grease. thanks for all the help
the oil will only make the squeaking worse - a lot worse.
