Stability Control
Old Oct 8, 2009 | 02:02 AM
yeahright's Avatar
Default Stability Control
I have a 2007 2 door JK with 3.5" lift and running 305/75/16 on Pro Comp 16x8 rims, I have also done the panhard rods, I am using a pro cal module from AEV and on most round abouts and any courners with bumps the stability control is continually being activated, is anybody else having the same issues or has anybody had the issue and had it corrected????
Old Oct 8, 2009 | 04:42 AM
2climbbig's Avatar
One thought comes to mind is that your steering wheel is not centered. If it is not center while driving strait it can cause you grief while turning.
Old Oct 8, 2009 | 05:47 AM
chickenman's Avatar
^X2..... it doesn't take much either to alert the nanny!!
Old Oct 8, 2009 | 06:02 AM
Locklain's Avatar
If your axles are shifted from the lift and not corrected with either a bracket or adjustable track bar this may attributed to the issue as well.
Old Oct 8, 2009 | 06:35 AM
i think down under they call panhard bars the trac bars, so yes he has adjustable ones. i would disable the system all it does is wear out your brakes. if you know how to drive you don't need it. imo
Old Oct 9, 2009 | 07:32 PM
yeahright's Avatar
Thanks,
I had the car in at the jeep dealer and they sent it out and got another wheel alignment and flashed the computer and showed me how the disable the traction control , and it is all good now, also we do call the track bar a panhard rod over here sorry for the confusion, funny we all speak english but htere is still a comunication barrier, nevermind thanks fort he help, you guys over there have more knowlege on the KJ than most do here.
Old Oct 9, 2009 | 08:49 PM
wildandwillin's Avatar
Originally Posted by yeahright
Thanks,
we can get it right... hope it all works out
