Stacking spacer Question?
Ok, here is the deal. I have the RC 3.25 kit which is a 2.5 coil spring and 3/4 inch spacer. I put a heavy bumperand winch on and have the rake again and my front tires are rubbing off road. I would like to buy a 1.5 inch front spacer to replace the 3/4 inch spacer up front. The problem is that no one makes one. Can I take another 3/4 inch spacer and put it on top of the other 3/4 inch spacer up front or is this bad?
Thanks.
Thanks.
thanks guys. After doing some measurements, I decided to go with an additional 1/2 inch spacer instead of the 3/4 inch. I want to make sure my front end doesnt get too high, rather have rake than the opposite. This should get it very close to level and give me a tad more ground clearance. I also went ahead and ordered front teraflex bumpstops. This will make sure to keep my tires out of my fenders along with the 1/2 more lift. I hate waiting, I want to do this project tomorrow.
If anything was going to fall out, it would have fallen out here:
I can also take my 2.5" TF kit and add an additional 1.5" spacer on top = Roughly giving me 4" of overall clearance for my tires. (Results may vary yada yada yada.)
Then I can take a 1.25" Body Lift and stick that on top of the frame, lifting cab. Which in the end won't give me anymore clearance BUT will help increase the overall passenger ride height from the stock position, to somewhere in the range of 5.25" ???
