Modified JK TechTech related bulletin board forum regarding subjects such as suspension, tires & wheels, steering, bumpers, skid plates, drive train, cages, on-board air and other useful modifications that will help improve the performance and protection of your Jeep JK Wrangler (Rubicon, Sahara, Unlimited and X) on the trail.
Fronts of both front tires are a bit closer together than the rears, correct? Lift it, the ca's are pulled up, tilting the axle pinion up, (lowering caster), which changes the toe slightly?
That's just a guess.
Castor change yes, but the tie rod is not touched when you install a lift, it's going straight from knuckle to knuckle, there's no reason to touch the tie rod, so I don't see how the toe can change from a lift.
With that said, I think the toe should be checked anyways, they've been known to be off from the factory. my buddy"s was off.
