Steering Box Mods
Old Oct 26, 2008 | 10:53 PM
TINMAN080's Avatar
The sector shaft brace looks like it prevents side loads on the shaft, but I don't see how it can avoid the transmission of forces that cause the splines to move on the shaft. That shaft doesn't twist, it's the splines that the pitman arm mounts to that ''twist''.....I could be very wrong, but this bracket looks like it would keep the box itself from laying over only....
Old Oct 27, 2008 | 05:47 AM
reddragons's Avatar
Thanks for taking the time to help me out. This information will really help.
Steve
Old Oct 27, 2008 | 07:56 AM
Leave Town's Avatar
Here's a pic of the ORE sector shaft setup...
Name:	P1030489 (Large).jpg
Old Oct 28, 2008 | 11:04 PM
reddragons's Avatar
Default gear box
Thanks for the pic, that gives me an understanding of how it works.
Does anyone know where to get a steering gear box, other than the dealer? Just looking for a better price. probably a long shot because the JK is only a couple years old.
Thanks,
Steve
Old Oct 29, 2008 | 08:59 AM
TINMAN080's Avatar
Default Found a supplier
I found this box at buy-steering.com. 1-888-924-7225. 07 wrangler power steering box, factory part #52088993. replacement part# 82-00434, $295.00. Core charge of $150.00 refundable upon return. Can ship today. 12 month warranty on box. Call and verify..... Hope this helps- Good Luck!!!
Old Oct 29, 2008 | 01:54 PM
reddragons's Avatar
Default Steering Box
Thanks, great find. I googled and couldn't find anything. The dealership wants over 700 dollars for a new one. Tinman080, thanks for all of your help. This forum is awesome.
Steve
Old Nov 30, 2008 | 11:04 AM
stewp97's Avatar
FWIW. This happened yesterday, pulling out of a parking spot on asphalt with the tires (35's) aired down. Didn't notice if the splines were twisted prior to this. Guess I need a new shaft as well
peter
Old Oct 19, 2009 | 05:40 AM
smartassjeff's Avatar
Default Mine broke also...
This was mine this morning in the parking lot. I had already taken 2 trips...glad I was not driving. Running 37" Grapplers. You can not just replace the shaft? You have to get the whole box?
ID:	31700   Click image for larger version
Old Oct 19, 2009 | 05:46 AM
GoodysGotaCuda's Avatar
Ugh you have to be kidding me, ANOTHER JK problem?! It seems like everything on these is vulnerable once you add tires.
Old Oct 19, 2009 | 06:07 AM
jsmoriss's Avatar
FYI - This picture shows a drop-bracket for the trackbar. If you don't use a drop-bracket, you'll need a good 3"+ bumpstop to prevent the trackbar from contacting the sector shaft bolt. I'm using a 2 3/4" bumpstop and it's too short (real-world testing by installing it and stuffing the driver's side).
js.
