Steering box problem
Old Oct 9, 2012 | 08:44 PM
69mach1's Avatar
Cool
Originally Posted by DeucesALLin
so... the sector shaft dosnt seem bent as it rotates snoothly. Seems to be a dust seal and a pressure seal. Now to remove them and find parts!
Very interested to see how this turns out also it would be a good idea to get your sector shaft magnafluxed before reassembling. My dust seal is kaput on my 08 steering box I'm thinking about carrying a spare sector shaft on the trails, since it's lighter than a whole steering box Let us know what part numbers you use and where you got them
Thanks
Old Oct 11, 2012 | 06:26 PM
DeucesALLin's Avatar
Gotcha! The sector shaft BENDS, not BREAKS so i dont see a mag. Being worthwhile. Everything ive read says that doesnt happen untill 37s. Espeacially with 2007-2009 units.
Old Oct 11, 2012 | 09:20 PM
69mach1's Avatar
Cool
I think the break is more common than bending ...hence the mag. Eddie's Moby just broke a sector shaft a couple weeks ago. I'm on 37's so I'm interested in what it takes to rebuild the box with new bearings/bushings and seal as where to get the parts
Old Oct 11, 2012 | 10:57 PM
D_engel's Avatar
give west texas offroad a call and theyll help you out
Old Oct 12, 2012 | 04:34 AM
robinson86's Avatar
After your rebuild you can install a sector shaft brace to add another bearing out near the end of the shaft. As it stands there is only one bearing to support the torques of turning those over-sized tires in rough terrain. Rock Solid Performance, JKS, and Synergy Suspension are 3 manufacturers that make them.
Old Oct 15, 2012 | 05:16 PM
Well, thats kinda a band-aid approach. I think I am gonna make a ram-assist steering setup to put all the pressure on the cylinder instead of the pump/sector shaft.
Old Oct 15, 2012 | 05:28 PM
69mach1's Avatar
Cool
I was thinking the same thing... except that quite a few folks including Eddie have broken sector shafts even with ram assist. I think that has to do with not "clocking" the steering box stops inside, therefore the ram is still pushing even though the pitman arm is at a physical steering stop. I went with a JKS sector shaft brace and things do feel more solid/less slop, at the same time I also installed a Synergy tie rod and drag link flip as well as Reid knuckles. I wanted the steering to be as stable and reliable as possible. Still am considering Ram assist in the future, I just think a Hemi should come first
Old Oct 15, 2012 | 06:38 PM
I actually only run 32" BFGs now, so a DIY ram setup is more because I want to take pressure off the pump and add a cooler.i just got the seals now comes the rebuild and tapping for the ram!
Old Oct 15, 2012 | 08:43 PM
69mach1's Avatar
Cool
Where did you get the seals? Did you get the sector shaft bushing too? I'll bet they're worn...
Thanks
