Steering and Font end problems
Old Nov 13, 2009 | 07:00 AM
Topher8668's Avatar
Originally Posted by JKBully
That's the most important thing to consider with any lift. A lot of people put their lifts on and then don't get it retoqued and post up crying about DW, etc. It's common. If you used a torque wrench, then there's a good chance you got everything torqued right. BUT, you should've hit all of the suspension bolts, even the ones you didn't loosen. Have them retorque that bastid, and then tell me that it's the lift's fault that it feels loose and wobbly. Good luck, keep me posted.
Thanks! Absolutely ill let you know what they say.
Old Nov 13, 2009 | 07:16 AM
JKBully's Avatar
NP
Old Nov 13, 2009 | 07:23 AM
N30EX's Avatar
One other thing to check is the steering shaft where it comes through on the engine side of the firewall. There is a black plastic bushing on the shaft that has been known to slide out of postion (down the shaft). When this happens the steering shaft will develop play leading to a loose feeling in the steering.
To remedy, tap the black plastic bushing back up into the firewall. Some guys have used a hose clamp on the shaft to keep the bushing in place. I used epoxy on mine when I had the shaft out for the Hemi conversion.
Best of luck,
-Randy
Old Nov 13, 2009 | 07:33 AM
Jusaplaya's Avatar
Check your trackbar extension. The screw on end of mine was loose on mine. Also pitman arm going to draglink needed tightening. Those needed to be tightened up on mine. Mine was popping cause extension on trackbar would flex some. Check to make sure the steering stabilizer bracket bolts aren't rubbing the tie rod. I had that happening too. Everytime I rotate my tires I am gonna check bolts.
Old Nov 13, 2009 | 08:22 AM
hammerhead's Avatar
If the lift was installed correctly you wouldn't be having any of these problems.
If you installed it and used a torque wrench why would you have them check it out. Loosen everything up and then tighten everything with the Jeep on the ground and make sure your steering is centered.
Old Nov 13, 2009 | 08:28 AM
nthinuf's Avatar
That kit comes with CAM bolts. Did you install them? Was the caster adjusted correctly at that time? Have they slipped, lowering your caster again?
Definitely something to look at, in addition to the trackbar and brackets. You might also want to remove the trackbar and check to see if the mounting holes are wallowing out.
Old Nov 13, 2009 | 08:30 AM
aldaman's Avatar
What a bunch of idiots! It has nothing to do with the quality of the lift at all.
I hope this is a TYPO , because not everyone that posted made that comment about the quality of the lift, but rather gave suggestions to try and find a solution for his dilemma...
Old Nov 13, 2009 | 08:35 AM
Piginajeep's Avatar
what he said, You should really get in the habit of check bolts often, before and fater trail rides, and during oil changes.
If you wheel the jeep enough, it will knock things loose.
Old Nov 13, 2009 | 01:43 PM
Jusaplaya's Avatar
Exaclty my problem. The guy down the road decided not to let the county scrape the road. He is dumb and his tractor isn't big enough to do the job. So it like an obsticle course every day going thru there. I wouldn't call this lift junk cause I have gave it hell so far and stuff is going to loosen up.
Old Nov 13, 2009 | 02:42 PM
JKBully's Avatar
Sorry for the misunderstanding aldaman! That was definitely NOT directed at you. You said nothing idiotic!
It was mostly directed at SuffolkJK. He comes into every thread that mentions RC and starts talking his sh!t and never ran an RC lift in his life. Just ignorant douchebaggery on his part. Plus he then got the OP agreeing that the lift is crappy, when the OP's probs were probably caused by his own ignorance and failure to maintain his rig properly. It's just sad.
