Steering Not Centered After Wheeling
Every time I go for hard core wheeling my steering gets off centered. I have a SOLID D60 Axles, with 4340 chromo heavy duty steel drag link and Tie Rod with 1 ton ball joints.
Checked everything is tight but how the hell does the steering goes off center
Also devloped a large clunk in the steering colum rattleing bad goins over bumps but not when i turn sterring left & right any clues???/
????Also devloped a large clunk in the steering colum rattleing bad goins over bumps but not when i turn sterring left & right any clues???/
Have you checked the splines on your sector shaft at the pitman? And or checked for any play in the box and or the box flexxing. Also the intermediate steering shaft for slop in the splines and the joints and firewall bushing.
I checked the pitman arm same position as before but i am also uing psc hydro assit which should take the stress out of the sector shaft
checked everything including intermediate upper and lower steering columns all seems to be good
Maybe its the freakin box itself, does psc do a rebuild on it with the kit or just plumb it?
I had this happen to me twice. I started making sure the drag link adjuster bolts were nice and tight evey time I go wheeling and it has stopped happening for me. I have gone wheeling 20x since I started this and no reoccurance. doesnt mean it isnt somthing more complicated but I would start by making sure the bolts r nice and tight every wheeling trip.
