Steering Not Centered After Wheeling
Old Oct 4, 2010 | 07:32 PM
JK07's Avatar
Default Steering Not Centered After Wheeling
Every time I go for hard core wheeling my steering gets off centered. I have a SOLID D60 Axles, with 4340 chromo heavy duty steel drag link and Tie Rod with 1 ton ball joints.
Checked everything is tight but how the hell does the steering goes off center ????
Also devloped a large clunk in the steering colum rattleing bad goins over bumps but not when i turn sterring left & right any clues???/
Old Oct 4, 2010 | 07:39 PM
mkjeep's Avatar
Have you checked the splines on your sector shaft at the pitman? And or checked for any play in the box and or the box flexxing. Also the intermediate steering shaft for slop in the splines and the joints and firewall bushing.
Old Oct 4, 2010 | 07:50 PM
JK07's Avatar
I checked the pitman arm same position as before but i am also uing psc hydro assit which should take the stress out of the sector shaft checked everything including intermediate upper and lower steering columns all seems to be good
Old Oct 4, 2010 | 07:53 PM
mkjeep's Avatar
Maybe its the freakin box itself, does psc do a rebuild on it with the kit or just plumb it?
Old Oct 4, 2010 | 09:45 PM
JK07's Avatar
Box was ported by WTO brand new
Old Oct 4, 2010 | 10:56 PM
fitzb's Avatar
check the flux capacitor........
Old Oct 5, 2010 | 04:24 AM
mkjeep's Avatar
Well damn.
Old Oct 5, 2010 | 06:05 AM
ronjenx's Avatar
Is there any evidence the adjustments on the tie rod or drag link are jumping threads?
Old Oct 5, 2010 | 06:10 AM
wayoflife's Avatar
JK-Forum Founder
just because it's chromo doesn't mean that a tie rod can't bend especially. likewise, pusing a super heavy 60, it's not impossible to have your track bar bend too. at least, it's happen to me before.
check the bushing that holds the column in place at the fire wall - there's one in the engine compartment that drops down and if yours has, tap it back up and it should help.
Old Oct 5, 2010 | 10:41 AM
Olean NY Jeeper's Avatar
I had this happen to me twice. I started making sure the drag link adjuster bolts were nice and tight evey time I go wheeling and it has stopped happening for me. I have gone wheeling 20x since I started this and no reoccurance. doesnt mean it isnt somthing more complicated but I would start by making sure the bolts r nice and tight every wheeling trip.
