Steering Pop
When making slow harder left turns I am hearing a pop. I recently had an alignment and the shop said my ball joints were good. Any idea what this may be everything looks alright and is tight.
It only happens when I am rolling above maybe 5 and on 90 turns. It seems to really do it when I hit a slight bump in the turn but also does it on smooth roads as well. I looked around and cant find a rub anywhere or anything that seems to be loose. The tie rod does have some play but the dealership said thats normal.
LOL!! that's a good one to check. back in late 2006-07, i had seen this on stock jk's right off the lot.
Originally Posted by SB5700
I had a similar problem - it was the sway bar link being slightly loose on the driver's side. I guess it was slipping in the joint and causing it to "pop"... Tightened it and viola!
I have a similar issue when I make slow right turns. I think its steering related because it locked up once. I need to fix it asap.
On the sway bar issue, that sounds more like a clunk than a pop. If it makes the sound over say a bumpy road, thats your links. No matter how lose my links have been, I've never heard the sound while turning though.
