steering problem...help
Old Feb 20, 2007 | 04:16 AM
TexasChopper's Avatar
Default steering problem...help
it appears that I have bent what looks like a shock and is connected to my steering. I can't turn the wheels to the right, as it's hitting a bracket. I have tried to bend it back, but does not seem to want to . question is can drive without it until I can get a new one?
Old Feb 20, 2007 | 04:19 AM
chvynova's Avatar
It sounds like your steering stabilizer. You should be able to drive with out it but you might have some bump steer.
Old Feb 20, 2007 | 04:20 AM
Piginajeep's Avatar
Thats your steering stablizer...
I'm sure the dealer can order a new one... I havent seen any out for the JK, I'll look around and see what I can find..
If your already lifted.. You might as well Upgrade to a beefier one.,
Old Feb 20, 2007 | 04:24 AM
i was thinking that was the stabilizer. I did manage to bend it down, some fluid leaked out, but the wheels will turn.
so just so I am 100% clear, I CAN drive without it for a bit?
Thanks for the quick response's
Old Feb 20, 2007 | 05:30 AM
mslc10's Avatar
you should be able to ,yes. I wouldn't drive very fast for frear of the dreaded shimmy but you should be able to drive. How did you bend it?
Old Feb 20, 2007 | 05:43 AM
nam6869usmc's Avatar
I would send you my stock one but you might just wanna upgrade to what I put on..Skyjacker Steering Stabalizer>>
http://www.quadratec.com/products/pr...+stabalizer+jk
[IMG][/IMG]
Old Feb 20, 2007 | 06:27 AM
I was driving around a construction site Sunday night and must have hit it. I really don't recall any particualr hard hit we took, but there is a small flat spot where it hit something.
That was a rare occurance being off the pavement, so I am just going to put a stock one back on it.
Old Feb 20, 2007 | 06:30 AM
...nam
just clicked on your link to Qtec...thanks, I was thinking a skyjacker would be a few hundred bucks, I guess for $36, it would silly not put a beefier one on.
Old Feb 20, 2007 | 10:19 AM
2climbbig's Avatar
I had that same issue. Just loosen the bracket and rotate it. That should give you enough clearance until you can replace it.
