Steering Question
Old Jun 19, 2011 | 06:08 PM
jrylb73's Avatar
Default Steering Question
Ok, I am not sure how to explain this, but I have a small amount of what I would call play in the drag link when I turn my steering wheel back and forth. I had my wife get in and turn the steering wheel left and right as I put my hand on the drag link and I could feel like a popping feel when she would turn it back and forth. Has any one had this before or does anyone have any ideas.
Old Jun 19, 2011 | 09:51 PM
RUBI2010's Avatar
I had a problem similar when i changed out gears from stock to 5.13 and didn't put the correct fluid back in so if you just drained the fluid or did some work in that area I would check into that...
Old Jun 20, 2011 | 01:51 AM
Jknockers's Avatar
Old Jun 20, 2011 | 02:52 AM
Widowmaker's Avatar
This happens to me because of a drop pitman arm. The opening for the sector shaft was not the right diameter and over time it had loosed up and would shift during turns.
Old Jun 20, 2011 | 07:16 AM
walker111's Avatar
Ball joints could cause the pop to be felt in the drag link...just a thought.
Old Jun 20, 2011 | 06:19 PM
fab1's Avatar
The ends go bad. I had both ends replaced under warranty. The long end that connects the knuckle is about $60 wholesale and is dealer only. But the short one can be bought at just about any parts store. I think this is the moog part # ES3624
Old Jun 20, 2011 | 06:39 PM
Beau's Avatar
Default Try 5th wheel grease first
https://www.jk-forum.com/forums/show...rease+steering
You may want to give this a shot before replacing any parts. Simple and cheap. I will be trying it this weekend, since my steering 'play' has become overly annoying.
