Steering shimmy/vibration question?
It appears that I get a shimmy/shake between 60-70mph, and it only happens when I am weighted down with cargo. Its also intermittant, it will happen for a mile or two, then stop for a while. Any thoughts? My specs are below.
Even though you just had them balanced, tires can go out of balance quickly, depending on the type of driving you do, how often you wheel, etc.
It's just my opinion, but I would give it a try, you may be surprised.
My friend was having similar issues and went through a slew of fixes until he finally pulled his steering stabilizer OEM shock off and the damn thing was shot and I mean dead. He replaced it with a rough country dual shock set up and never had the issue again. You may want to check.
