Steering Stabelizer
Old Jun 18, 2007 | 04:17 PM
BLKRuby's Avatar
Default Steering Stabelizer
What one do you guys recommend? Are they universal fit, or are there JK specific?
Old Jun 18, 2007 | 04:47 PM
IGOFSHN's Avatar
There is absolutely nothing wrong with a stock stabilizer. There is no need to upgrade.
Old Jun 18, 2007 | 05:00 PM
BLKRuby's Avatar
1. Ok, Thank You. But,
2. Are there any answers to my questions
Old Jun 18, 2007 | 05:07 PM
usmcdoc14's Avatar
ok I will answer:
I recommend the stock one or none at all.
If you do go with a aftermarket one they are pretty much universal.
The only JK specific one I recommend is the stock one and when that one gets bash to heck on the trail I recommend not having one.
Old Jun 18, 2007 | 05:08 PM
101gargoyles's Avatar
Former Member
There is a TSB out for the orientation of the stock stabiliser. Depending on which end is mounted closest to the right wheel. Check it out cause they won't turn them around untill after it's leaking (not working) and that can be deadly in the right conditions.
Not all vehicles have one but those that do NEED them.
There's a thread out there about some aftermarket dampers not fitting well and getting damaged by hitting other parts.
Old Jun 18, 2007 | 05:16 PM
usmcdoc14's Avatar
Originally Posted by BeerMonkey
my 35 13.50's cause they are super heavy and did nt balance perfect
why? tell me how they did not and I will give you advice on how to fix your balance problems. brand of tire as well.
Steering stabilizers have a tendency to mask more serious problems
Old Jun 18, 2007 | 05:26 PM
ludorhb's Avatar
Default Stabilizer
I use the skyjacker one. I noticed an improvement over stock.
Old Jun 18, 2007 | 05:37 PM
Former Member
Superlift #sup 92050 for 07 Unlimited Rubi - others available all 07's covered.
Old Jun 18, 2007 | 06:18 PM
jared1843's Avatar
I got one from Superlift. Should get the time to install it this weekend.
Old Jun 18, 2007 | 06:23 PM
1BADJK's Avatar
Everyone has an opinion.. But if you run in the sand dunes its a must..
