Steering stabilizer question
Old Dec 21, 2011 | 06:57 PM
Xodius's Avatar
Default Steering stabilizer question
Ow long do these last and how do you know when they are shot? My JKU has just over 36k and is a 2008. The steering is a little...loose perhaps. I have never had a SFA which is why I ask. Thanks all.
Old Dec 22, 2011 | 01:59 AM
Battlefrog's Avatar
Your steering being loose probably doesn't have anything to do with the SS. As for how long they last, I can't give you a definitive answer. Easiest way to tell if it's bad is if it's leaking. Or, take it off and see how difficult or easy it is to compress.. If its easy with little resistance, it's probably shot. If its got some resistance and can here the compression, it's still good. Hope this helps....
Old Dec 22, 2011 | 02:58 AM
Bnizzle's Avatar
X2^^^^
Old Dec 22, 2011 | 03:13 AM
kleinrider's Avatar
I have an '07 with 56K miles and just took mine off to put heavy duty one on for my bigger wheels/tires setup. The stock one was still ok, so I doubt yours is bad. I would however check it like what was said above to be sure.
Old Dec 22, 2011 | 12:47 PM
Xodius's Avatar
Sounds good thank you.
Old Dec 22, 2011 | 01:35 PM
robsjeep9's Avatar
JK-Forum Ambassador
I had my lift put on Dec 2010 and my new teraflex one lasted only 9 mo's before it starting leaking
Old Dec 22, 2011 | 01:42 PM
CottonFire's Avatar
I just replaced the stock SS on my 08 with 25k and I could compress it with VERY minimal effort...
I love my new Fox...after all the Teraflex leaky ones in glad I didn't go that route.
Old Dec 22, 2011 | 02:12 PM
Tonka_yellow's Avatar
Take the shock off and pull on it. If it comes out smooth and kind of hard to pull then its good. If it goes loose then tight and kind of skips its bad
Old Dec 23, 2011 | 06:58 AM
jeepmedic's Avatar
I am on my 5th one in 3 years, plus the factory. Iv done stock, pro comp, teraflex x2, and now Im on my fifth....tried a Rancho this time. O'Rielys parts store here in town will warranty them for life with the receipt.
Have only smashed one..all the rest have just started leaking like a siv after about 8 months or so.........IMO they are all junk
