Steering Stabilizer Relocation Kit Super Easy
Old Jun 14, 2008 | 07:04 PM
smokie298's Avatar
Default Steering Stabilizer Relocation Kit Super Easy
I just put this on today and it only took a 1/2" drill bit, a socket wrench and 30 minutes. It’s nice if you want to upgrade your Steering Stabilizer from the wimpy stock Chrysler s/s to a nicer sturdier s/s also giving you less to worry about when climbing because it’s mounted higher. I also noticed a smother freeway ride when changing lanes. Not as much sway. The stock s/s is about 1" if that thick. The procomp that I bought is about 2" thick and I’m sure built with better precision. Anyways heres somepics.
Old Jun 14, 2008 | 07:20 PM
aldaman's Avatar
Originally Posted by smokie298
I just put this on today and it only took a 1/2" drill bit, a socket wrench and 30 minutes..................
Nice...Did the Pro Comp S/S come with the relocation bracket or is that the woods relocation bracket and what was the 1/2" drill bit used for? Thanks..
Old Jun 14, 2008 | 07:30 PM
JulietKilo's Avatar
Its the woods, it requires you to drill out the left hole in the bracket attaching it to the track bar mount. The stock hole is too small for a bolt so you drill it out to allow the use of the second bolt (smaller one on the left attached to the bracket)
This is a must do, and woods makes a great kit. I have a write up over here with lots O pics.
https://www.jk-forum.com/forums/show...woods+steering
Old Jun 14, 2008 | 07:34 PM
smokie298's Avatar
JulietKilo said it all. I love the whole thing so far though.
