Steering Stabilizer Suggestions
Old Feb 14, 2018 | 01:40 PM
Jeep in the West's Avatar
Post Steering Stabilizer Suggestions
Hello all,
This is my first post to JK Forum.
My Rubicon Express steering stabilizer gave out on me, and I'm hoping for some suggestions on a new one. I've been looking at the Bilstein 5100 (# 24-158428).
Is this a good one? Anything better in a similar price range? Any suggestions are much appreciated.
Thanks!
Old Feb 14, 2018 | 01:41 PM
jadmt's Avatar
JK-Forum Ambassador
Originally Posted by Jeep in the West
Hello all,
Thanks!
pretty hard to beat the stock OEM stabilizer.
Old Feb 14, 2018 | 02:02 PM
nthinuf's Avatar
Did you happen to read the end of the description?
NOTE: THIS IS A PRESSURIZED STEERING STABILIZER, AND WILL LIKELY PUSH YOUR VEHICLE TO THE LEFT WHILE DRIVING.
As mentioned, the stock stabilizer is fairly well known to work just fine. If you choose to spend a bunch of money on something fancy or shiny, that's up to you. And if you need an extra heavy duty stabilizer to cover up a driveability issue caused by other failing components, you are probably better off putting the money toward fixing that issue.
Old Feb 14, 2018 | 02:18 PM
Hahaha! Wow. I hadn't read that. THANK YOU. That would have been annoying.
I'm not opposed to replacing it with OEM. I just figured I need something because the one I have on there now is dumping oil out of it.
My steering components are all in decent shape. Definitely don't need the stabilizer to bandaid anything.
Old Feb 14, 2018 | 06:30 PM
resharp001's Avatar
Loved
Community Favorite
that is one of the very few parts on our jeeps that the factory, or the cheapest thing out there, is perfectly fine. unfortunately, 99.9% of the other stuff leaves much room for improvement.
Old Feb 15, 2018 | 05:09 PM
swizzle's Avatar
Vet Army
I just installed Teraflex's 9550 VSS on mine, I was also replacing the tie rod and drag link. But when I pulled the steering stabilizer off it was really easy to push/pull it making me think it was pretty worn out.
Old Feb 15, 2018 | 07:01 PM
How do you like the Teraflex? I’ve also been looking at that one.
Also, if you don’t mind me asking, what tie rod did you choose? I just replaced my drag link, and plan on soon replacing the tie rod, but haven’t decided on what brand of tie rod.
Old Feb 15, 2018 | 07:41 PM
LoboMike's Avatar
I also went with the Teraflex 9550. I've had it on for just over a year now and it's worked great. Absorbs bumps and potholes on the road much better than the old leaking Rancho one I had on there.
Old Feb 15, 2018 | 08:48 PM
Taylor520Tucson's Avatar
Fox ATS if your willing to spend it, it is definitely worth it.
Old Feb 16, 2018 | 05:17 AM
BlueBaby's Avatar
On our Jeeps I've run the stock ones, FOX and now the Falcon 2.2. The Falcon is a nice piece, needed it for the beefier tie rod.
But the stock one works just fine for stock tie rods.
