steering stablizer
Old May 8, 2008 | 09:01 PM
ChewyGranola's Avatar
I'll crawl under there tomorrow to check again, but I don't think its hitting.
I'll also try to get a pic from underneath so you can see.
Old May 9, 2008 | 06:53 AM
Here is a pic from underneath.
Old May 9, 2008 | 06:54 AM
Is this the bolt that you are having issues with?
Old May 9, 2008 | 06:55 AM
derekls's Avatar
That acutally looks just like mine.........from the bottom view
What would be causeing the marks on my track bar, it would have to be the stabilizer wouldnt it?
Ill go take pictures and post them
Old May 9, 2008 | 06:56 AM
derekls's Avatar
Yes sir, thats the bolt
Old May 9, 2008 | 06:58 AM
RedneckJeep's Avatar
All you have to do to position the stabilizer right is make sure the piston is extended about 1/4" out at FULL compression of the stabilizer. Simple enough.
Old May 9, 2008 | 07:01 AM
My thought is to just flip the tie rod bracket around. should have better clearance.
I don't know if that would work with the stock axle mount though.
Old May 9, 2008 | 07:07 AM
He said that he it is set up right. 16 3/4" eye to eye.
Old May 9, 2008 | 07:12 AM
The method I gave will work with ANY stabilizer, no matter the brand. A blind man could set it up using that method.
Old May 9, 2008 | 07:14 AM
derekls's Avatar
Mine is set up right, it works, it just appears that there is contact with the track bar at some point, because there is marks, here is the pics:
