Steering upgrade?
Old Feb 15, 2011 | 07:27 AM
Koloradokid's Avatar
Default Steering upgrade?
So I'm having ridiculous issues with bump steer now with my lift and was wondering If it's worth investing in either a currie hd draglink and tie rod system or rock krawler similar system or should I just stick with a dropped pitman arm and save a couple hundred bucks?
Old Feb 15, 2011 | 07:29 AM
wayoflife's Avatar
JK-Forum Founder
are you saying that you have a dropped pitman arm installed now and if so, do you have a track bar relocation bracket installed too? if not, that is your problem right there. you NEED to have both installed.
Old Feb 15, 2011 | 07:39 AM
BKGM Jeepers's Avatar
Usually bump steer and death wobble are caused by either miss-aligned drag link/ trakck bar angles or worn out bushings/loose bolts.
Take a pic of your front geometry and post it.
With most lifts over 2.5", I'd consider the high steer option. I run high-steer and a 4.5" lift and the stock pitman arm with no vibrations whatsoever.
Old Feb 15, 2011 | 07:52 AM
As you can see, all I have is an adjustable track bar. No dp arm and no relo bracket. So I guess as Eddie is sayin I need both or can I just do the high steer kit an be good?
ID:	127596   Click image for larger version
Old Feb 15, 2011 | 07:55 AM
wayoflife's Avatar
JK-Forum Founder
installing both a track bar relocation bracket and dropped pitman arm OR draglink flip will help improve your handling as it will restore your steering geometry back closer to stock again. you cannot just do one or the other.
Old Feb 15, 2011 | 07:58 AM
rinkishJK's Avatar
to run a "flip" u do NOT need the tie rod bar. u NEED a flippable drag, like the currie, AND a track bar relo bracket like WOL said.
Old Feb 15, 2011 | 08:04 AM
Okay, I gotcha. So I'll either go with the currie or teraflex flipped draglink and a relo bracket. Thanks guys!!
I don't want to give my fiancée an excuse not to run shamrocked!!
Old Feb 15, 2011 | 08:12 AM
wayoflife's Avatar
JK-Forum Founder
there will be no excuse to not come to shamrocked - PERIOD
Old Feb 15, 2011 | 08:25 AM
Yeah, like I'm gonna tell her that!! No, we are definitely going, I just want her to drive!!
Old Feb 15, 2011 | 09:29 AM
You don't need the sleeve if you get a staged taper ream.
The price of a 7/8" drillbit (if you don't already have one) + the sleeve ($15) is more than the ream. If you were close to me, I'd let you borrow mine.
I run the flipped drag link and the Track bar lowering bracket with the stock pitman arm. No bump steer or death wobble.
