Steering wheel issue
Old Jul 30, 2008 | 05:39 PM
AdamH's Avatar
Default Steering wheel issue
Lift is done, alignment is done (myself, always done them myself).
after centering the steering wheel, tightening everything down, it will stay straight for a couple days then get off center. I have re-centered it 2 more times and get the same result a couple days later. Funny thing is that it gets to one point and never gets worse.
Any ideas?
Old Jul 30, 2008 | 06:42 PM
JK-KJ's Avatar
can't help ya, but I'd like to know myself...I need to center mine, but just haven't done it yet.
Old Jul 30, 2008 | 09:55 PM
kubwa_jim's Avatar
For what it is worth. I recently flipped my steering stablizer from under the tie rod to over the tie rod. In the process, I had to unhook the trackbar from the axle. Once finished, I had to adjusted my steering wheel. Now, I've noticed it is not quite right again. Since the only major change I made was to disconnect and then reconnect my track bar, I am hoping that is where the problem lies. I have actually been waiting for Thursday, (when I have time) to check it out and make sure it is tight. You might give that a look.
Old Jul 31, 2008 | 04:56 AM
Bodo's Avatar
Sounds like a good place to start. Have you noticed any "flighty" steering? Seems like if it was loose you would notice some steering issues.
Old Jul 31, 2008 | 04:58 AM
j&k'sjk's Avatar
sounds like a loose trac bar
Old Jul 31, 2008 | 01:48 PM
AdamH's Avatar
Yall are thinking the same way I was.
Track bar is adjustable and is tight and hasn't loosened at all since I installed the lift.
Every thing else is fine. Steering is fine, just the wheel is off no matter how many times I center it.
Old Jul 31, 2008 | 02:39 PM
twillis724's Avatar
Default Off Center Steering wheel
I don't know if this will help but I took mine into 4X4 parts to have a new track bar installed and an allignment. All was OK when I left but the steering wheel soon began to drift off center. Got the famous ESP light. I took it back and they told me that they had a new service sheet from Jeep that said when alligning and centering the steering wheel the wheels had to be off the ground. They redid it and I haven't had any trouble for a month now.
Old Jul 31, 2008 | 03:32 PM
WRAITHYJEEP's Avatar
get the woods steering stabilizer bracket
as this item will shore up and prevent the trackbar from moving 1 to 5 millimeters with in the stock axle bracket
even torquing it down 20PSI over stock seems to help to ya jar the wheel but once i put on the woods SS relocation bracket it holds everything firm
Old Aug 3, 2008 | 04:59 PM
AdamH's Avatar
I remember reading that someone on here had this problem but I can't find it when searching.
I hear ya on the Woods relo bracket however I'm wondering if there are other options.
Has anyone had this problem and found a different solution?
