Stiffer springs
Old Nov 18, 2013 | 08:06 AM
Derrick_Merwin's Avatar
Default Stiffer springs
I am interested in buying a new bumper and winch for my jeep I don't want the front end to sag but I do not want to lift it yet what spring rate would be good to support the added weight I'm not interested in getting a ton of lift from the new coils just want them to support the added weight also should I just get new front coils or all new coils I'm not putting a new bumper on the rear
Old Nov 18, 2013 | 09:38 AM
Offroad_Elements's Avatar
Former Vendor
Measure from ground to fender prior to install, install winch and bumper. Measure again and determine a thicker coil spacer to put in the front. Usually 1/2" to 3/4" will give you the proper sag offset.
Let us know if you have any questions, or let us know if you'd like any pricing on the bumper, winch, or coil spacers!
Old Nov 18, 2013 | 12:05 PM
Gforce!'s Avatar
From: Independence and Lexington, KY (depends on the time of year)
^^^Sounds like good advice to me. OR if you have a 2-door or a non-rubi JKU, you could switch out for stiffer rated stock springs from another JK who lifted their rig. I can't say how this would affect your ride quality, but I've heard of people gaining significant lift from switching spring rates, and it would more than likely compensate for your loss in height from the added weight.
Old Nov 18, 2013 | 12:17 PM
Gman*2007's Avatar
What is the last 2 numbers on your current springs?
Old Nov 18, 2013 | 05:15 PM
hooper's Avatar
Just add 1/2" or 3/4" spacers.
Old Nov 18, 2013 | 06:17 PM
JKBANDIT55's Avatar
just get rough country springs. They are stiff enough to make you think your running 100psi in the tires. No sagging and they make your head go like even when you hit the smallest bump in the road
dont know why I bought them.
Old Nov 18, 2013 | 06:44 PM
Dahmer's Avatar
Not sure what's wrong with yours, my RC springs ride fine. It rides only slightly worse than stock.
Old Nov 18, 2013 | 08:09 PM
JKBANDIT55's Avatar
I'm on my 2nd set. They warrantied the first. Rear springs settled big time.
And your right it never used to drive this ruff. I really need to measure if they are sagging again because it's way stiffer than before
Old Dec 28, 2013 | 07:40 PM
jeepmojo's Avatar
Default is there a thread how to install a spacer ?
can a person do it by them self with no experience or is this a major project that can get you into some shit you didn't expect ???
Old Dec 28, 2013 | 07:45 PM
Jeepstin12's Avatar
disconnect the shocks, lift the vehicle at the frame, the springs should fall out. IF there isn't enough drop, disconnect the axle, lower control arm mount. You're talking 8 bolts max. Also, remove the clip from the brake lines. Allow them to move a bit and be careful not to drop the axle too far. Easy as a store bought pie.
