Stuck hub/shaft
Old 04-25-2016, 01:03 PM
  #21
ShutterBug's Avatar
Originally Posted by ronjenx
Why apply heat to the stub shaft end? The axle shaft is not preventing unit bearing removal in any way.
I was making an assumption that the stub shaft was stuck on the unit bearing.
Old 05-01-2016, 06:58 AM
  #22
JKBud's Avatar
Making progress drilling out the broken off hub bolt. Assuming I remove the axle shaft nut and nuts on the ball joints, there should be nothing from stopping me to pop off the whole knuckle and hub to get a better angle correct?
Old 05-02-2016, 03:19 AM
  #23
Potato Potato's Avatar
Correct.
Are you planning on drilling and using an easy out? With the hub and unit bearing removed, I would recommend welding a nut to the broken stud. The heat will help loosen the fastener as well.
Old 05-02-2016, 07:33 AM
  #24
JKBud's Avatar
Originally Posted by Potato Potato
Correct. Are you planning on drilling and using an easy out? With the hub and unit bearing removed, I would recommend welding a nut to the broken stud. The heat will help loosen the fastener as well.
Yes I plan drilling it out but I don't think an easy out will reach as pretty much all the threads except two of the bolt are snapped off in the knuckle/hub. My best bet is to drill it out and rethread the hole.
Old 05-02-2016, 04:51 PM
  #25
Didn't realize it snapped off so deep. Re-tapping two threads should be no problem. Good luck man.
Old 05-04-2016, 03:58 PM
  #26
JKBud's Avatar
Finally got the shaft out, the hub was so seized on it came off with it. Now I can easy out the bit that's left in it. Top ball joint was surprisingly tight and the bottom was shot. A torch, pb blaster, and bfh did the trick.
Quick Reply: Stuck hub/shaft
