Stuck on Size!
So i can get a set of nearly new 35'' bfg mt's for dirt cheap, however their on a 15 inch rim diameter. Are the performance gains from having a 17'' rim for a 35 compared to 15'' that great? I'm thinking of things such as street handling and off-camber situations offroad. Oh and everyone with 17's/35'' combo, do you feel you have enough tire to air down low enough? Thanks for reading everyone, help me decide!
I don't think there is a performance difference between a 15 and a 17 inch rim. The overall tire diamater is still going to be the same. There may be a little difference in weight but not enough to make a noticable perfomance difference. I run 15" wheels and tires and I haven't had any issues.
Thanks 09Rubicon, personal experience is exactly what I'm looking for. Seems like the 15 inch rim has been the standard for awhile and only recently have larger rims come into play. I drive mainly on city streets and offroad, very little highway, so sounds like this should work. The sidewall flex in turns was one of my main concerns but I suppose at slow speeds it shouldn't be too significant. Anyone else with experience please chime in!
I run the 35-12.50r17 KM2's at 5-10 psi with beadlocks with no problems. I have aso run the 15" MT/R on beadlocks. Both are great. The only difference will be at higher speeds and corners. You can always bump the psi up in a 15" to make up for the added sidewall height.
