Suggestion for a control arm full kit ?
Old Aug 2, 2010 | 05:53 PM
MasterG's Avatar
Default Suggestion for a control arm full kit ?
I'm looking for a set of control arm. rear, front, upper and lower.
I'm not a serious offroader and you can look down below for my jeep mod.
I'm looking for BFG km2's 33x12.5 too.
Tereflex Monster ? (1150$)
Rough Country X-Flex ( 699$ )
Rubicon Express..
Full-Traction..
Skyjacker...
Any advice is appreciated..
Old Aug 2, 2010 | 06:01 PM
I have the daystar full kit....not too many people run it, but it is a quality kit. The good thing is that it's also fully adjustable in case I go upto 6" springs in the future
I too am not a crazy offroader, but wanted my jeep to ride right after raising it 4.75"...the daystar kit definately got the job done, and I think when the jeep is raised anything over 3" the axles kind of come together a little bit, so you have to extend your control arms to push them farther apart just to get it to look right again.
Old Aug 2, 2010 | 06:16 PM
Full-Traction Suspension's Avatar
Former Member
Check out our 3" premium plus, it's not quite a full kit, it just has uppers, track bars and everything else. but they are just what you need to correct the pinion and caster on the 3" lift. The link is in my sig with the full details. It's made in the USA
If you have questions please ask,
You can add lowers to make it a complete 8 arm kit,
Rubicon Express..
Full-Traction..
Skyjacker...
Old Aug 3, 2010 | 03:07 AM
MasterG's Avatar
Also... do I need to bought a full set to correct driveline angle and alignement ?
or just upper or just lower will do the job ? ( or front / rear only..)
Thanks everyone !
Old Aug 3, 2010 | 03:36 AM
jeepnick's Avatar
Thanks everyone !
Just front lower or uppers and rear uppers
But if you get a deal on a kit u might as well to fine tune everything
When u get rear lower depending on how far back u go u need to take a few other things into consideration springs sway bar hitting bumpstops and or axle tubes
I have teraflex up front and rock krawler in the rear the rock krawler arms are pretty sweet and at a decent price point
Old Aug 3, 2010 | 05:33 AM
Former Member
Thanks everyone !
Uppers work fine front and rear, the adjustable track bars in the kit align the axles in the jeep.
These two jk's run this kit with no additional parts other than what's in the kit. The black two door is running flat fenders to fit 37's.
3" premium plus on 35's
3" premium plus on 37's
Old Aug 3, 2010 | 07:45 AM
TeraFlex's Avatar
Sponsoring Manufacturer
Rubicon Express..
Full-Traction..
Skyjacker...
Take a look at this Control Arm Comparison that TeraFlex created. It will help you compare the differences in the way control arms are made.
http://www.teraflex.biz/tech/faq/con...-comparison-2/
TeraFlex uses clevite bushings on the lower arms at the frame end to help maintain stock like quiet ride. At the axle end you'll find rebuildable/greasable quiet flexjoints. TeraFlex has a few dealers in Canada also, if you have any questions please let me know.
Old Aug 3, 2010 | 07:47 AM
Rock Krawler Suspension's Avatar
Former Vendor
Sir
If you have any questions on any of the Rock Krawler kits, please let us know. For a full featured kit we would suggest a 3.5" X Factor System with high clearance lower control arms front and rear! The system is all inclusive and replaces all factory hard parts with our product. All of our hard parts come with an Abuse Proof Lifetime Warranty!
Good Luck with your build.
Rock Krawler
