suggestions on approach to a 3.5" kit
Your are correct on this after further research 500 per shock...
A 3.5" lift for a 4 door will likely require a front and rear driveline mod and that is going to run you about $1k +/-. The RE 3.5" kit highly recommends replacing both the front and rear drivelines with aftermarket drivelines.
I heard that on the 2 door but I had not realized a 4 door was having this same issue of needing driveline replacement. You'd think they would just make those part of the kit.
That's not to say you wouldn't get improved quality/durability/clearance from a new one, but me, I'm going to wait until I see how my new lift (if I ever decide
) fits before shelling out the extra $$.See the FAQ for confirmation.
Clayton says neither is necessary on a 4door. Airock says you can lower the tranny plate (I think) w/some washers to get the front to clear. From what I've heard, the only reason you need a new front d/s is 'cause the aftermarket ones are smaller in diameter, so they clear.
I just pulled the trigger on the Clayton 3.5". Should be here in a week or so.
