Suggestions needed to install winch on stock bumper.
Old Mar 4, 2018 | 06:04 AM
  #21
amok's Avatar
Active Streak: 90 Days
Active Streak: 120 Days
I used the Rough Country winch plate with D rings:
Old Mar 5, 2018 | 12:17 PM
  #22
Rednroll's Avatar
Originally Posted by TakeABackRoad
Curious if any of you installed a winch on a stock bumper. Did you get a winch plate or modify the bumper? Or am I better off saving up for a new bumper? Mine is stock with the exception of cutting the ends and capping them.
Was trying to go with a cheap solution that works.
Essentially you need to do both from my understanding. The stock bumper is not strong enough to mount a winch on it by itself. There has to be a winch plate. The winch plate mounts onto the front frame rails, and then the winch onto the plate.
When I looked at modifying the stock bumper, it just seemed like too much work for what it was worth. I rather go out and get a cheap china bumper than fool around a compromised solution anyhow. Fortunately for myself, someone had an AEV front bumper on CL for $250, so it became a best of both worlds solution for me. Those options are sometimes out there as well. It just takes some patience and some shopping.
