Suggestions please!
Old Feb 6, 2007 | 12:09 PM
AndrewZ's Avatar
Default Suggestions please!
I am getting ready to order my 3 inch lift for my 2 door Sahara(also on order) and have a few ??? for the more knowledgeable jeepers on the forum..
I am going to use my Jeep 75% of the time on the road the other 25% of the time on moderate trails.. So road handling is more important than flex..
What 3"kit, as well as what shocks with that kit ,would give me the performance I seek??
Cost is less of a concern than proper performance of the suspension is.. I am also going with 35's on stock rims with 1.5" spacers..
So what kit and shocks would you recommend??
So please point me in the right direction guys..
Thanks
Old Feb 6, 2007 | 03:32 PM
Renegade's Avatar
I don't think anyone has actually done a "seat of the pants" comparison of the various lifts on the Jeeps. There seem to be advantages and disadvantages to each one. I have the Teraflex 3" and the 1 advantage I think that it has is a better/stronger rear track bar bracket. I have seen pictures already of JKs with the factory axle-mounted track bar brackets rippped off when using "riser" brackets (which bolt to the axle instead of the frame). I know that Skyjacker and Rancho both use this type of bracket. I don't think anyone really knows which lift "rides" better yet or what the differences in spring rate is between the companies. If I was to build the exact kit I wanted it would probably use various pieces from several different manufacturers.
Old Feb 6, 2007 | 04:44 PM
TexasChopper's Avatar
I realize your asking about a different kit, but let me pipe in that mine wanders around with a 2.5BB, 1.5 spacers, and 35's on my stock 18's. I can handle it, but I know a few people that I would not let drive it around some of the rough backroads I travel around on a lot.
I don't know what lift Rubimon has on his, but he said something about his doing the same thing. This may be something condusive to the 2Dr's with the short wheelbase. I think most people that have lifts on here have the 4 doors, so there really is not an abundance of info just yet.
