Which Superchargers can be fitted with a dual battery in place.
Hi,
Thinking about having a supercharger fitted, however I know not all fit if you have a dual battery setup (AEV/Magnusson etc).
I have a '09 Sahara with the M.O.R.E dual battery tray.
Suggestions please.
Cheers
Suggestions please.
Cheers
I don't have a dual battery set up in my JKUR, but I have been thinking about the same thing because I want to have a dual battery set up and supercharger too. So, I did some looking and found RIPP Superchargers. For future reference. It's a medium sized unit that mounts to the front between the air filter & engine.
My vote is for the AEV/Maguson. The entire setup sits on top of the motor and away from dual battery setups. Plus, you get better usable power compared to the ripp charger. Ripp's centrifugal charger is fine for race cars, but for a jeep where you want low end torque, the AEV roots style charger is a way better option.
Why don't you choose whatever supercharger will best suit your needs and do a battery relocation? I have my battery relocated in the rear if the jeep and utilize my old battery tray for other things like compressor and distribution block. I don't run a dual better set up so I may be missing the bigger picture here.. Just a thought though.
Nope, The magnuson won't fit with dual or the factory battery setup. It does sit on top but then hangs over the passenger/battery side. It also comes with a replacement/relocation (single) battery tray. It's a great supercharger, one that I'd like to have if a dual battery solution could be had.
One could always consider a higher output alternator if a single battery is not keeping up with your power needs though, or use a tuner to raise your idle speed to help the stock one put out a little more juice at idle - I have a Warn Zeon winch, ARB twin, lockers, 4 rigid dually's, lifetime led reverse light, CB, coolant pump for the supercharger intercooler, and a few other things I'm forgetting off hand I"m sure as well... and have yet to ever run into an issue with the single stock battery not keeping up.
