Superchips Error - Car is dead -HELP
#21
The stereo won't cause any issues, but it does store a code that the radio is missing even if you use the proper harness.
The only way was if there's a fluke in their software that correlates a 'stereo missing' code to a no run condition. Highly unlikely but possible if their software is flawed.
Sent from my DROID4 using Tapatalk
I then start up the vehicle and it runs fine with no code. I turn it off and back on and I get a no communication with radio code. I turn it off and on again and I get a no communication with radio code, no communication with PCM code, a no communication transmission module code and two other miscommunication codes
Then after sitting for five minutes the vehicle will not start again. I am at a loss here. My tuner says it is up to date when hooked up to spark now too.
#22
That's the craziest thing and even odder that it won't wipe your computer clean to allow you to return the jeep to normal operation. Any word if superchips will pay for you to take it to the dealer and have them force a clean flash on it? That's the only thing at this point that I think would get you back to a reliable place. It would lock the tuner, but if they are aware of the issue then they *should* unlock it for free for you.
I'm going to stay subscribed here to see what I can offer you as far as solutions go.
#23
Last update of the night. The vehicle still will not start after sitting for five minutes. To get it to start I have to clear the codes and click return to stock.
#24
Here are a few of the codes I am getting.
Just to disclaim, I am posting this for people's knowledge/reference not to bash Superchips. I could not find any threads on superchips errors so I decided to document this here as I am sure I am not the only one who is/have had this issue.
I just talked to them again. Even though the update on the tuner says it was sucessful on Spark, they think that it was not sucessful. They advised me to hard wire into the internet instead of using wireless to complete the update. I am skeptical of this but what other choice do I have. If it doesnt work the PCM and Tuner are being shipped to them.
#25
Only thing I can think of is your new radio might be jamming your CAN bus (cannabis?).
All smart devices (PCM, ACM, ECM, TCM, BCM, DCM, CCM, ICU [and I see you too]) talk to each other over the vehicle wiring using a digital carrier signal protocol called CAN bus that travels on top of the 12VDC. Any device that has capacitors or inductors (and sometimes diodes) on the power side of their circuit can attenuate or garble that communication.
CAN bus - Wikipedia, the free encyclopedia
I know the Superchips instructions says to turn off and unplug all accessories before programming but just turning off your radio might not be enough. You might have to disconnect (unplug) it or at least remove the radio fuse.
#26
Heck it could have been free and it would not be worth the headache for me. OEM's are trying to stay one step ahead of the aftermarket so who knows what safe guards are in place?
#27
Admittedly,, I dont know much about superships tuners,, I used a ProCal to adjust my jeep; however, I can tell you that I used a PAC with my stereo upgrade as well, and it messed up my bluetooth abilities and some stereo controls. After trying several unsuccessful fixes, we finally took out the PAC and went with a much cheaper version of a connection. It worked like a champ. I wish I could tell you what we used,, but I cant remember. Regardless,,, remove the PAC and try again. At this point it seems like you have tried everything else, what can it hurt.
#28
Watching this thread and hoping everything will turn out ok. I also get nervous every time I change a tune or unplug the tuner, what you describe would be one of my nightmares.
#29
Did what superchips asked me to do today. Left with the same issue, and 2 codes, invalid internal memory checksum and failure to communicate with radio. I have been without a reliable car for 5 days.
Update: I just spoke to a friend who tuned for diablosport and now owns a top mustang tuning company. He said the code pretty much means the PCM is done. I will call superchips again tomorrow.
Basically that means that there is an interal fault in the Powertrain Control Module (PCM). There have been many reported PCM failures on Chrysler/Dodge products. In Dodge/Chrysler products, a P0601 trouble code means that a serial communication failed inside the computer at least 6 times.
A code P0601 in most cases means the PCM has gone bad. This is possibly due to a short-circuit inside the PCM. Or, if you disconnect the wires/connector from the PCM while the battery is still connected, that may also cause this code.
With a P0601 OBD-II trouble code, the most common fix is to replace and reprogram the PCM. In a few cases the dealer may be able to reflash the PCM and get it working. But more than likely the PCM will need to be replaced and reprogrammed
#30
aldaman
