Superchips Flashpaq for JK, Initial Impressions
Hmm, i'm from Australia, really interested in getting the Superchip Flashpaq, but over here our premium fuel is a supposed "98 Octane". If there's no tune setting for 98, I'm wondering what the resulting performance will be... We do have 93 octane here too though.
http://www.m3post.com/forums/showthread.php?t=259770
http://www.btinternet.com/~madmole/R...RONMONPON.html
I remember the octane rating was really high in Germany also, but they use a different formula than in the US. You may want to check the pumps to see what formula they use to compute octane. The US uses R+M/2. Try these links:
Two days ago I let my tank get pretty empty and filled up with 91 to try that tune. Seems to have even more off the line, but it looks like I lost a little of the mileage improvements. Hard to tell if that is because of the change or because I was hitting the pedal a little harder to see what I would get.
After a couple tanks of 91, I want to try to find a station with 93 to try that tune as well. I have stock tires on a 09 Rub.
Does anyone have any suggestions about my situation.
I have the Flashpaq which I think is great.
My engine had occasionally a slight knock/clunk under acceleration before I started using the Flashpaq.
I took the Jeep into 3 different dealers and none of them can find anything wrong.
Now, when I am using the 87 Flashpaq tune, I can really notice the knocking/clunking and is easily recreated.
Any ideas on how I can show these "experts" at the dealer that there is a problem during a test drive without having the computer programmed with the Flashpaq.
Once they see I have the Flashpaq, they will blame the Flashpaq for ruining the engine.
Any suggestions?
Thanks.
Any suggestions?
Thanks.
Okay well I was lucky enough to Demo a Tuner for Friday and Saturday. Here is my first impression.
Pros-
Throttle delay is much better when driving the 6spd
Pulls better, struggles less in all gears
6th gear pull is noticeably better
TPMS was cured
Speedo was cured
Cons-
*Spark Knock on 91 performance tune running 91 octane
*Takes a LONG time to put a tune in (5mins or so?)
*The crawl tune sucks for a stick shift. In my opinion. I am used to crawling with my clutch pedal, in the "crawl" tune it wants to stall and needs more gas to do the same things. The idle needs to be brought up and the same throttle delay needs to be there to make this tune useful.
Major con was the guys at the event didn't give a damn about what i had to say about their tuner. Blew me right off, and it didn't seem to matter that I didn't feel like dropping the $330 on it at the event. Guess it doesn't really matter how it works in the real world?
Will i buy one? Yes. However I'm not chomping at the bit to drop the money on it right this second..
Pros-
TPMS was cured
Speedo was cured
Cons-
Any suggestions?
Thanks.
Any suggestions?
Thanks.
FWIW.. I changed out my plugs and wires before I installed the Flashpaq..
